Volk TE37's 18" Billig
Moderator: geiserp
- Vorname: Richard
4x Volk Racing LE37T (limited edition TE37's)
2x 18x8.5" Felgen mit reifen 225/40/18 Goodyear Eagle f1
2x 18x9.5" mit 255/35/18 Goodyear Eagle f1
![Image](http://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/308279_10150337729806054_669191053_9471498_4063143_n.jpg)
![Image](http://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc7/308279_10150337729811054_669191053_9471499_3704485_n.jpg)
![Image](http://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc7/308279_10150337729816054_669191053_9471500_5484692_n.jpg)
![Image](http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/308279_10150337729821054_669191053_9471501_6200547_n.jpg)
![Image](http://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/312159_10150337730161054_669191053_9471502_8011942_n.jpg)
![Image](http://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc7/312159_10150337730166054_669191053_9471503_3554575_n.jpg)
![Image](http://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/198601_10150164455561054_669191053_8113355_1647722_n.jpg)
![Image](http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/198601_10150164455571054_669191053_8113357_8286038_n.jpg)
![Image](http://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc6/189174_10150164458301054_669191053_8113409_4246709_n.jpg)
![Image](http://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc6/252551_10150253584081054_669191053_8682780_4714406_n.jpg)
![Image](http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/255793_10150251670871054_669191053_8659733_4930307_n.jpg)
€1900 jetzt nuer €1500
These are a forged one piece aluminium wheel using the FORMEC technology.
They are made from the finest aircraft grade 6061 aluminium. The wheels are made by a process called hot forging. A solid piece of aluminium billet is heated and is shaped applying compressive force from a press.
The 1st forging process is performed with a pressure of 5,000 kg’s per cm2. In the 2nd forging process 3,500 kg’s are applied per cm2. The lip is also forged to 3,500 kilograms per cm2.
Forging refines the grain structure and improves the physical properties of the metal. With the advanced RAYS design process the grain flow can be oriented in the direction of principal stresses encountered in actual use. Grain flow is the direction of the pattern that the crystals take during forging. Physical properties (such as strength, ductility and toughness) are much better in a forging than in the base metal, which has, crystals randomly oriented. The excess material left on the wheel is then machined off (to tolerance of 1/100 of a millimetre). Powder coating and clear coating is done by a special proprietary process to ensure long lasting quality and durability.
This is why forged wheels can be made much lighter and stronger than an equivalent cast wheel, as less material can be used for a much higher equivalent strength. Cheap wheels are gravity cast, and during this process microscopic air bubbles form in the casting, weakening the structure further over the original material.
- Vorname: Steffen
Re: Volk TE37's 18" Billig
so billig das es umsonst ist! Ich nehme se ![Smile :)](./images/smilies/icon/smile.gif)
Ahhh jetzt mit Preis![Smile :)](./images/smilies/icon/smile.gif)
Reservier sie mal bitte für mich 1-2Tage.Hab jemanden der Interesse hätte.Muss ihn nur mal morgen anrufen.
Gruß Chris
Gruß Chris
- Vorname: Richard
Wieder moglich zu kaufen.
MfG Richie
MfG Richie
- Vorname: Richard
Hi Luk, was ist ET?luk# wrote:ET?
- Vorname: Richard
Die sind Volk Racing LE37T (limited edition TE37s)
8.5x18 ET30
9.5x18 ET35
8.5x18 ET30
9.5x18 ET35
