ca18det and sr20det OEM engine rebuild gasket kit
 Moderator: geiserp
desa
Einsteiger
Einsteiger
Re: ca18det and sr20det OEM engine rebuild gasket kit
Post by desa »
have few sr20det engine gasket kits without turbo gaskets 140Eur
Also have few rb26dett genuine engine gasket kits without turbo gaskets ONLY 120Eur
desa
Einsteiger
Einsteiger
Post by desa »
Gasket kits and other rebuild parts available
desa
Einsteiger
Einsteiger
Post by desa »
Engine rebuild gasket kits available
desa
Einsteiger
Einsteiger
Post by desa »
SR20DET gasket kit 170
CA18DET gasket kit 170
Also available other rebuild parts like piston rings, water pump, oil pump, head bolts and many more
lol-o-mat
Spamabfrage: Sexbot
Post by lol-o-mat »
Can you source OEM oversize SR20DET pistons?
dichtung leerlaufventil.....gibt es die auch einzeln?
diesen gummiring um die schraube.....
desa
Einsteiger
Einsteiger
Post by desa »
lol-o-mat wrote:Can you source OEM oversize SR20DET pistons?
Hello STD size is available only
desa
Einsteiger
Einsteiger
Post by desa »
kanntenzwerg wrote:dichtung leerlaufventil.....gibt es die auch einzeln?
Hello that IACV valve is only as whole unit, can't get separate parts from it
desa
Einsteiger
Einsteiger
Post by desa »
Gasket kits available
desa
Einsteiger
Einsteiger
Post by desa »
available, also many other rebuild parts for nissan engines(ca18det,sr20det,rb25det,rb26dett)
